StuartyM2021
hey all. I just changed my oil, filter and air on my c220 and now the car is in limp mode and give fault P246309 DPF issue … any ideas on what it could be or what I should check. The fault won’t clear. Thank
Hallo I have the dame problem. How did you solve it? Thanks a lot for the answer.hey all. I just changed my oil, filter and air on my c220 and now the car is in limp mode and give fault P246309 DPF issue … any ideas on what it could be or what I should check. The fault won’t clear. Thank
Ho did you solve the problem?hey all. I just changed my oil, filter and air on my c220 and now the car is in limp mode and give fault P246309 DPF issue … any ideas on what it could be or what I should check. The fault won’t clear. Thank
