Dears,
I have C200 Compressor Elegance Model 2004
My gear box shows Error "P2502 Trans Slipping", What is the mean of this error?
And how I can solve this error? and the cost for it please.
And Please could you answer me how the error is caused.
I have changed the filter and fluid for the gear recently.
To make everything clear for you; I have change the Water Radiator for my car because of the water having gear fluid in it. (There was no problem here with my gear transmission, it works 100%)
Then after changing the Radiator, I have discovered fluid leaking because the mechanic didn't connect the fluid tube correctly, I have drove the car in this situation for less than a one mile.
Finally I have change the Radiator again and refilling the fluid and change the filter.
Finally, The leaking is off, but the gear transmission is so bad, and computer gives me the following error
Please advice guys, I am about to pull my hair. !!!
