I wonder if anyone could give me a bit of advice on the above code?
2006 420GL. As I understand it this is a small motor that sits in the middle of the V on top of the inlet manifold. Are the swirl flaps operated only during starting or are they active during normal driving too? Given that the code appears to be pointing to a positional feedback issue is this likely to be due to general wear in the linkage which looks quite extensive from the photos I have seen? The code was current when I plugged the iCarsoft in but after resetting did disappear so the car came out of limp mode. It will only be a matter of time before it happens again though. So what are the options here? The motor itself is not expensive but if it wear in the linkage that is causing the problem is this repairable. There looks like there is a bodge to force a healthy signal but I’m not keen on that approach in general.
Andy
Andy
