Hi guys, just a quick one. I own a c220 cdi 2011. I came back from holidays and the car is throwing fault p245414, differential pressure sensor.
shall i just order one from Merc as I have located and found the part number or there is something else that I can check prior?
Part cost £65 but I’ve seen a Merc video that it says might be the wiring harness?
Suggestions more than welcome.
Could this have an effect in the gears as for the moment I can’t manually change up gears and the car is not revving more than 3.200?
Cheers
Cheers
