paddleshift
login_user
Hampshire
CLK350 CAB Sport (w209)
just received my paddle shift converter from command on-line. and will fit my black series wheel into my clk tonight. For £170 for a converter first impressions aren't good. you gat a tiny little box that looks like it cost £10 off ebay china, a metal plate 4 screws and 2 bits of card. No instructions. Not that you should need them, although it would be nice if it was marked left and right, so I might have to swap the paddles over to get the correct operation. will post if it works later.
Right! a peed off!. opened up the steering wheel to find the new style paddle controller, even though it has the up/down buttons on both sides on a 55 reg. No way will the converter fit. So as they looked the same I swapped it over. A quick spin up the road and all is well.
