Paint and masking tape question
reflexboy
Surrey, UK
E350 CDi Sport&SLK250CDi AMG Sport
When painting a wheel arch inner lip with hammerite, when is the right time to remove the masking tape? Let it dry totally, or pull it off carefully whislt still tacky? TIA
CKLclive
Banned
CLK 430
when its still tacky and why are you painting your inner wheelarch lips
with Hammerite ?
OP
OP
reflexboy
reflexboy
Surrey, UK
The lips will be covered with trim, filled and sealed with Bilt Hamber S50 and special sealant to prevent moisture being trapped. Thanks for the masking tape advice Clive
CKLclive
Banned
CLK 430
Ok, if you have corrosion on the inner lips use the acid first then phosphate treatmemt, and coat them with Rustbuster epoxy primer it will stop miosture
from getting to the treated surface, dont use hammerite to seal it please
it do's not work trust me
oldcro
Shetland
Range Rover Sport 3.0 HSE
Remove the tape as soon as you finish painting.
