Paint Costs
shanksy
Andover
W124 e220 coupe + W208 CLK430
Hi all,
I managed to pick up a replacement passenger door and front wing for my W124 coupe this weekend. Both were in fantastic condition and got the pair for £150 which i'm well pleased with, looking forward to the prep work now.
I plan to paint the panels myself and will be getting some quotes tomorrow for the paint, however I don't really know what is reasonable.
I will basically need enough to cover the 2 new panels plus a few other small touch up areas.
Does anyone have any pointers as to what I should be expecting to pay ?
What colour is the car? If its a light metallic forget painting it yourself- even the pros find it difficult to match. Mercs of that age used Glasurit paint so I would go to a wholesaler that supplies that make. Color-Online
Its a non metallic red.
One particular bodyshop I used a couple of years ago for an insurance claim matched the drivers door and wing perfectly.
Hopefully they will be reasonable on cost as presumably they will still have the paint mix on file
Apparently it is Imperial Red, any ideas on expected cost ?
just the paint really, if the labour was cheap enough i might be tempted to save myself the hassle but more than likely i'll spray myself
If you have done a bit of spraying yourself before --fine otherwise I would leave it to the pros- they have the best equipment and environment controlled booths. As to paint cost can't help there- just get down to your local car paint wholesaler- tell them the area you want to paint and the type of paint you want to use and they will advise a suitable primer and paint finish. This might be worth a look? How to Paint Your Car: Bk. M2583 Motorbooks Workshop : 1 Motorbooks Workshop: Amazon.co.uk: Dennis W. Parks, David H. Jacobs: Books
thanks for the advice guys. I have plenty of experience spraying so not concerned about doing myself. my main convern is getting a proper match.
I'll report back with my quotes in case its of use to anyone else
