Panel filters
Senna11
UK
C63S
Any suggestions for replacing filters on C63s? Looking for aftermarket rather than OEM and don’t want issues with MAF.
(post in correct section:rolleyes:)
From just a change of air filter?
Or would that require a new induction kit?
Alternatives such as BMC are usually much better than OEM.
I was joking ....
One would gain nothing from a simple filter change. Airflow is not restricted by the OEM filter.
Change the induction pipe size, filter size and throttle body and a dyno remap then you might see a small increase in power
Some good testing and insight in that video...
@whitenemesis how many additional torques, and can filter be used with resistor power mod off eBay?
As mentioned in previous posts then when combined with a tune then a good filter in an enclosed box will assist. Gains at best are marginal but tend to be an improvement on stock filters. Foam or Cotton?
Snake oil springs to mind.
For me, such tweaks dont pass the bum dyno.....
On my old S2000, a K&N filter made naff all difference...a full induction kit resulted in a lot more noise...and a drop of 2-5 mpg....
They should be able to give you a definitive answer, unlike us armchair critics 😉
Does anyone have a link for a UK BMC Supplier?#
Would like a set for the C63S
