I've narrowed the drain down to two rear 7.5 amp fuses
F3 and F8 in the boot ..
when I remove these the drain drops right down but I need to chase the connections and think I need schematic if someone can help ..thsank you..also cant lock doors with the key when they are removed
3 | TPM [RDK] (tire pressure monitor) control unit PTS (Parktronic) control unit Navigation processor TV combination tuner (analog/digital) |
8 | Left antenna amplifier module Alarm horn Alarm signal horn with additional battery ATA [EDW] inclination sensor |
