The adjuster is inside the brake drum on the rear wheels. Remove each wheel in turn, line up the adjuster with the hole in the drum and turn with a screwdriver till the wheel wont turn then back it off so it spins free. The shoes dont usually wear out as they are only applied to a stationary drum.
But it sounds as though with that much travel you may have a streched cable that needs replacing.
Bloody hard to spot. Be prepared for some bad language, loss of skin and a hangover. Anyway Ray, how come you are advising You aint done it yet, its this poor sucker who does yours
