parking brake adjustment
SiLeach
C200 Kompressor Coupe
I have a 2002 C200K Coupe and the parking brake needs adjusting
When I pull the lever to release the brake, the pedal doesn't rise all the way up, this in turn leaves the light on the dash lit, which in turn start a very loud alarm as I drive off.
As I pull the release lever , I have to place my left foot under the pedal and help it up.
Is this easily adjusted and sorted, or is it a trip to the garage ?
Advice would be appreciated, thanks
Could be the pedal return spring is broken / weak
Cable adjustment is at the rear, access via a panel underneath the rear seats. parking brake shoes are adjusted via a small access hole in the rear drums
