I occasionally have the same problem with my '03 W211. I wonder if it's likely to be the same cure? It releases satisfactorily, but the light does not always go out. WD40 will do the job OK, by the way, though I have some GT85 somewhere as well.
The parking brake on the W211 is pretty punk, though; the W210 before it was much better. Is this normal, or do I just have a dud?
grumpyoldgit said:WD40 is basically a water displacer and is fish oil based hence the 'WD', not the best for use as a lubricant or penetrating oil.
