Parking lamp warnings
Discussion in 'Electronics' started by DJBozz, Jan 11, 2019.
  1. DJBozz
    DJBozz New Member
    7
    Jan 7, 2019
    Guildford
    Car:
    C200 Estate Avenguard SE 2005
    Hi everyone I an new to the club & Mercedes cars, I have just got a 2005 C class Avenguard SE estate, I have warnings for both front parking lights but they are both working, I have replaced the bulbs with Osram OEM spec bulbs & checked all connection terminals but not fixed, any help would be appreciated , many thanks.
  2. OP
    OP
    DJBozz
    DJBozz New Member
    7
    Jan 7, 2019
    Guildford
    Car:
    Any ideas please
  3. Ted
    Ted MB Club Veteran
    5,327
    Feb 26, 2004
    Bourton on Dunsmore
    Car:
    SLC 250D AMG Line, Yamaha XVS 1100, Jeep Renegade
    Are they standard incandescent bulbs you changed it with?
    If it is, it may be worth fitting a pair from a Mercedes dealer just to be sure.
  4. OP
    OP
    DJBozz
    DJBozz New Member
    7
    Jan 7, 2019
    Guildford
    Car:
    Yes standard type 5w capless bulbs, I've tried 3 different bulbs even Osram MB spec? I'll get some from MB & try them, thanks
    Ted likes this.
  5. Uky
    Uky Hardcore MB Enthusiast
    124
    Jun 23, 2006
    Car:
    C207
    Some vehicle control boxes are extra sensitive to inbalance between lamps.
    Therefore always replace both sides when one is gone.
  6. OP
    OP
    DJBozz
    DJBozz New Member
    7
    Jan 7, 2019
    Guildford
    Car:
    I've seen this on the web so I've changed them both twice for different brands even though they are working, I've called my local MB who have them in stock, I'll get them Saturday & try again, thanks
  7. Oldlae
    Oldlae Active Member
    91
    Mar 9, 2016
    Merriott Somerset
    Car:
    S204
    I had the message remain on after replacing the bulbs.....cancel the message manually.
    Tony
  8. Yugguy
    Yugguy Hardcore MB Enthusiast
    1,840
    Apr 6, 2016
    Rugby UK
    Car:
    W204 C220CDI Elegance with Comand
    make sure light switch and ingition are off before you change them.
  9. OP
    OP
    DJBozz
    DJBozz New Member
    7
    Jan 7, 2019
    Guildford
    Car:
    I've looked to cancel manually but there doesn't seem to be a way to do that, thanks
  10. Oldlae
    91
    Mar 9, 2016
    Merriott Somerset
    Car:
    S204
    Read your handbook! On my S204 you just use the buttons on the steering wheel.
    Tony
  11. OP
    OP
    DJBozz
    DJBozz New Member
    7
    Jan 7, 2019
    Guildford
    Car:
    Well, after fitting a new pair of parking lamp bulbs from MB, the warnings are still there, there is no way to clear the warnings using the command system, any other ideas? or do I just live with it.
    Thanks.
Share This Page
