Discovered the other day my front drivers side parking sensor was showing alarm but was clear all round. Located a plug behind the headlight up above the wheel Arch liner and tried to open/close incase it was a bad connection inside. Problem solved and all sensors front and rear worked OK. Or so I thought, same happened again yesterday, same thing, played with the plug and cured it. Today just beeps and 4 solid red leds on the dash, they come on every time the vehicle slows to 10 mph. Until I just switched off using the dashboard switch.
I managed to reach inside the wheel arch and disconnect the plug so now none seem to work.
I'd rather just have the back ones than none at all work so is there a way to just disable the front until I can find out whats wrong and replace them and is there an obvious way to tell which ones knackered without reading codes? Don't have a code reader.
