Diego06
Hi. Let's just clear one thing up before anybody else says it.....I'm an idiot!!!
In an effort to 'reset' my non functioning Nav system I followed a post from one of the MB forums, I forget which but anyway......that post said to remove & replace a fuse from the dash fusebox (the one on the end of the dash, between it & the door). IIRC it was a 7.5amp fuse & it was located at the bottom end of the fusebox. However when I got out to the car I couldn't remember which fuse it was so I pulled out all the 7.5amp fuses & put them back.
Firstly, it didn't cure my non functioning DVD nav drive & secondly since then my parking sensors are not working in reverse. The front ones are fine but as soon as I put it into reverse I get a long beep & red lights before it switches itself off. I guess it could be a faulty sensor but it seems quite a coincidence it started immediately after pulling fuses. So there ya go, I'm an idiot for blindly following the first post I found with an 'answer' & I'm an idiot for thinking that pulling fuses with the ignition off couldn't hurt anything. I don't know where my head was that day
Anyway, does anyone know if I can reset the parking sensors? (I've given up on the dvd drive, I think it's knackered)
