Parrot installation on C class 02 reg.
Mbclk2008
Kent
clk, 2.1 CDI, 08, sport
Hello,
Can anyone recommend Parrot or any other quality hands free systems for my C class 02 reg. Don't want to bother with pertable like Parrot minikit. Want some serious ones.
Also, which of the Parrot system is easy to install?
Regards & thanks
Tom
Nokia CK-7W
They are still available and are excellent. Pair it with your phone, press the button and it activates the voice calling on the phone. The sound quality is very good and it's easy to use.
Io play 2. Same connections as parrot, but far superior sound quality. Will allow a iPod or music streaming too.
My wife had the parrot mki9200 fitted to her Astra yesterday. So far so good. Sound quality is good and music sound through a USB stick seems so much better than the cars radio.
Hello,
Regards & thanks
Tom
Your car will be standard ISO (assuming you dont have Bose) so fitting is just plug and play.
I actually might have BOSE system as sound quality just superior. If that's the case any much complicate to fit?
Also what cable do I need to buy?
Cheers
Tom
If you have BOSE it is significantly more complicated to do any thing (i.e to change the head unit or to add a Parrot as the speakers are connected to amplifier which is in the rear, which connects to the stereo with fibre-optic connection.
So, for Parrot you need to run all the cables to the boot and find the appopriate cable to connect to the amplifier
So find out if your car has BOSE
Cheers
Richard
