guydewdney
Thought I'd start a new project which will be useful.
Part numbers are made up of four sections:-
AAA BBC CC DD
A refers to the chassis (202, 140 etc) B refers to the general area the part is used. for example 01 are engine related - so 016 is head related oil things (cam gaskets etc) 053 and 050 are both valve related (as in inlet valve)
So - if you know of a part number, can you post the second three digits, and what it refers to?
this is unashamedly stolen from http://www.mercedes-veterans.com/tech/group.htm
Group No. Group
01 engine housing
03 engine moving parts
05 engine timing
07 fuel injection
09 intake muffler
13 compressor for air conditioning system
14 intake pipe and exhaust manifold
15 electrical parts at engine
18 engine oil system , -filter
20 engine cooling system
22 engine suspension
24 engine suspension
25 clutch
26 manual transmission
27 automatic transmission -
29 pedals
30 control
31 frame
32 springs and suspension
33 front axle
35 rear axle
40 wheels
41 propeller shaft
42 brakes
46 steering
47 fuel system
48 oil tank
49 exhaust system
50 radiator
52 undershields
54 electrical equipment and instruments
58 tools and accessories
61 frame floor unit
62 body front end
63 side panels
64 tail
65 top (fixed)
67 windows
68 covering
69 covering
72 front doors
73 rear doors
75 rear lid
77 folding top
78 sliding top
79 hardtop
80 vacuum system
81 interior appointments -
82 electrical equipment and lighting
83 ventillation and heating
84 trunk support
86 windshield washer -
88 chassis sheet metal -
89 vehicle accessories / body mounting
91 front seats
92 rear seat
97 seat accessories Sitz-
98 general parts
so far...
016 head gasket
014 sump gasket
490 exhaust
80x vacuum?
090 brackets?
094 mas sensor
010 dipstick
018 dipstick guide / bracket
542 oil sensor
053 valve seat (in + exh)
050 valve seat (in + exh)
031 crank
030 flywheel
if this bit could be added to we could build up a huge database so any part number can be identified as tyo what it is...
I'll host this as an excel file on my server.
AAA BBC CC DD
Group No. Group
01 engine housing
05 engine timing
07 fuel injection
09 intake muffler
25 clutch
29 pedals
30 control
31 frame
33 front axle
35 rear axle
40 wheels
41 propeller shaft
42 brakes
46 steering
47 fuel system
48 oil tank
49 exhaust system
50 radiator
52 undershields
61 frame floor unit
62 body front end
63 side panels
64 tail
65 top (fixed)
67 windows
68 covering
69 covering
72 front doors
73 rear doors
75 rear lid
77 folding top
78 sliding top
79 hardtop
80 vacuum system
84 trunk support
91 front seats
92 rear seat
98 general parts
so far...
016 head gasket
014 sump gasket
490 exhaust
80x vacuum?
090 brackets?
094 mas sensor
010 dipstick
542 oil sensor
031 crank
030 flywheel
