Part number question (bulb)
Discussion in 'Electronics' started by SilverSaloon, Oct 30, 2008.
  1. SilverSaloon
    SilverSaloon MB Club Veteran
    7,759
    Mar 16, 2004
    Car:
    1994 W124 E300D Estate, 1985 R107 280SL
    hi
    apparently its important to get the right bulb for a 124 instrument cluster to avoid it burning/melting the inside of the cluster....
    i've found this part number:
    N072601012240
    on the net and according to inchcape website its a bulb.
    Can anyone confirm its the correct bulb for a W124 instrument cluster illumination?
    cheers!
    Derek
  2. partsspecialist
    partsspecialist Hardcore MB Enthusiast
    411
    Jul 22, 2008
    Bolton/Manchester
    Car:
    Ford Focus TDCI
    I can confirm that it does fit a 124 instrument cluster and its a 3w bulb and there are 3 of them.
    However there are also some 1.2w bulbs in there. make sure you change like for like and you'll be ok.
    (wattage is written on the bulb)
  3. OP
    OP
    SilverSaloon
    7,759
    Mar 16, 2004
    Car:
    Thanks - according to the US website where i got the part number from the illumination is 3w. He advises no more than 3w otherwise it melts.
    I'll double check my exisitng bulb 1st before swapping over.
    Only 1 bulb is out (rev counter side is not lit anymore) so hopefully i only need 1.
    thanks
    Derek
Share This Page
