Passenger Airbag light - Heater M2/16 motor replacement
mbz124
Hi all, I am about to pull take off the top of the dashboard to get at the M2/16 motor which is clicking.
When I remove the top dash the passenger airbag has to be disconnected - does this require a reset afterwards with star?
thanks
Presumably w203. If you keep the key out of the ignition you should get away with it. An ignition on cycle with the airbag unplugged will lodge a fault code
Thanks its for a W203. Would I be better off disconnecting the battery instead?
