Steve292
I am new here, so please bear with me. I have an E320 w211 on a 55 plate
My nearside (LH )door mirror led indicator stopped working. Shortly after someone bent the mirror assembly forward, breaking the power adjuster linkage.
I have replaced the entire assembly, including the Led with new parts, not second hand and it is still not working. I have sourced and fitted a door control module,(second hand) and thats not worked either. The 30 amp fuse has been replaced in the drivers side dashboard fusebox with no joy. My Icarsoft diagnostic tool tells me that I have fault 920B wire break to component or component fault. I can read the data on the door module and it all seems ok. I have between 13.97 and 14.03 volts to the module,(both modules) measured via the Icarsoft tool, so I assume the power supply to the module is ok.
Does any one have any ideas please? I have tried swapping various components around with no joy. I can't see any earths to clean and find it difficult to believe that brand new components would repat the same faults as the old ones.
Many thanks in advance.
Steve
Steve
