2019 Glc coupe 350d was 2017 e350 c207 .. +65 ford kuga 2.0 cdi zetec awd..
Anyone using a pela pump know if I can repair the valve on the top , the suction is only lasting a short time , I suspect a leak up top . Wondering if it's fixable at all ???
Edit . Found this on pela site , I'll try a clean.
So today I popped this top off , underneath is a rubber o ring . I cleaned the whole thing with brake cleaner and reassembled . I'll give it a try with water later today and watch how it performs.
Edit . 2 litres in 40 strokes up hill. Before it ran out of puff . Not sure if that's good or not . ??
Once started by establishing a reasonable vacuum with a few pumps flow should continue without more pumping-sounds as if you still have a vacuum leak or a faulty/worn pump?
