Petrol - RON values on the pumps
Discussion in 'OT (OFF Topic) Forums' started by gaz_l, Sep 1, 2011.
  1. gaz_l
    gaz_l MB Enthusiast
    2,319
    Mar 12, 2006
    Car:
    Mini Cooper S, BMW M140i
    Greetings, citizens.
    Filled up tonight at the local Shell station, which was recently refurbished. Probably the second/third time I've done so.
    However, I noticed this time there's no RON numbers on the pump labels - fairly sure that before regular was labelled as 95 and V-power as 98. I thought it was a legal requirement to display the RON values of petrol on the pump, is this just me having another senior moment or have the goalposts moved? I've had a shufti on the Shell website and it's a mine of no information..
    Cheers,
    Gaz
  2. DrFeelgood
    DrFeelgood MB Enthusiast
    9,280
    Nov 10, 2005
    Car:
    BMW 740Li
    At my local Shell the V-Power is labelled as 99 ron on the pump handle, the rest are not labelled.
  3. markjay
    markjay MB Master
    25,015
    Jun 24, 2008
    London
    Car:
    W204 C180 Executive SE 2013 Automatic / COMAND NTG4.7 and Morel speakers fitted by www.comand.co.uk
    Shell V-Power - Wikipedia, the free encyclopedia
    'In the United Kingdom and Denmark (where Super Unleaded must be a minimum of 97 RON), V-Power has a rating of 99 RON (whereas V-Powers' predecessor Shell Optimax was rated at 98 RON). There is one other 99 RON fuel available in the UK, namely Tesco MOMENTUM99.'
  4. DrFeelgood
    9,280
    Nov 10, 2005
    Car:
    BMW 740Li
    Previous post might have made me seem a bit over observant, not the case.
    My Beemer only runs right on V-Power and I spend £700 a month on the stuff so have had plenty of time looking around Shell forecourts recently.
  5. verytalldave
    verytalldave MB Enthusiast
    3,595
    Aug 26, 2007
    Bromley, Kent
    Car:
    W203 C200K Cubanite
    What would happen if you used "ordinary" unleaded ? ?
  6. corned
    corned MB Enthusiast
    3,894
    May 2, 2008
    Living in error with Maude at Cap Ferrat
    Car:
    car
    No bang for your buck. Or a rather subdued one at least.
  7. verytalldave
    3,595
    Aug 26, 2007
    Bromley, Kent
    Car:
    W203 C200K Cubanite
    So it can be used - you just get a lower level of performance ? ? ?
    Basically the same as any modern car ?
  8. corned
    3,894
    May 2, 2008
    Car:
    car
    Generally, yes, but in more severe cases it can cause pre-ignition (pinking) and other rough running issues.
    1 person likes this.
  9. DrFeelgood
    9,280
    Nov 10, 2005
    Car:
    BMW 740Li
    Apparently there are some injector and high pressure fuel pump issues with the 3.0 petrol.
    Car just runs rough on 95ron, also seems brand makes a difference.
    It hates BP fuel, brought on a engine management light on supermarket stuff.
    On the plus side I see 35mpg which isn't too shabby for a large petrol engined cruiser.
    Also, the car is a petrol manual (as opposed to my last diesel/auto) and I'm surprised that I need to give it a fair gunning before changing up to prevent pinking.
    Anyone noticed that CLS auto/diesel are becoming soo much more affordable?
Share This Page
