- Nov 6, 2007
- Location
- North Oxfordshire
- His - Denim Blue A220 AMG Line Premium / Hers - Obsidian Black R172 SLK55
Back in November 2008 I put a pair of these in the dip beam lamps on my W204 in an effort to get a bit more light on the road. I must say that at the time I wasn't exactly convinced that they were anything like 80% brighter than the OEM bulbs, but hey-ho, I'd spent just over 30 quid on them so they stayed in.
Tonight on the way home from work (in daylight I might add, but I run with the lights in Auto mode so they were on) I had a warning come up on the instrument cluster telling me that one of the dip beam bulbs had failed. Once home, I replaced the failed bulb with one of the OEM ones and tested the lights against the garage door. So, with one bulb allegedly 80% brighter than the other it should be easy to tell which one's which, right? Wrong! I defy anyone to tell me which side has which bulb fitted. If I could be bothered, I'd take a piccy and post it up to see if anyone can work out which one is which from the light output but as you'd have a 50-50 chance of guessing it right I'm not sure the test would be statistically significant
When I think about it, all the published tests are on the larger-capsule H4 bulbs and I suppose the Philips X-Treme Power bulbs may well be brighter than run of the mill stuff in that format, but as far as the H7 capsule's are concerned I'm unconvinced.
