Phone Connection W221
220Apc
I am wanting to buy a Mercedes Bluetooth adaptor to work with the Command unit, I have a cable in the armrest not the usual uma slide connector, photo below of connector on the lead, is this the same connector as the uma or different please? Can anyone point me in the right direction how to enable Bluetooth with a adapter via this cable or other means please.
You should have mentioned that this a Japanese market car, isn't it? Not much use for that plug here.
Hi yes it was a Jap import, is that the problem? Anyway around this thanks.
Don't know how to define a problem here but this is a Docomo specific connector and basically only used in Japan. Since telematics control units are quite unique for the Japanese market, I'm not even sure if the phone control unit could be swapped with a ROW part. Perhaps ComandOnline have some experience.
