Pioneer SATNAV
T
tanuie
Guest
Hi
Just replaced the Comand 2.0 with fibre optic Amplifier with a Pioneer Avic F960BT SATNAV. Although not able to use the existing Amplifier/ subwoofer, the guy who fitted it wired the door speakers (Harman Kardon) up directly to the Pioneer which has an amplifier in it anyway, the sound quality is still as good, and the steering wheel controls work as they should and also the clock on the dash is also showing correct time which I didn't expect (however, time will tell when the clocks go back whether it will correct itself).
Hi, Will do.
Pictures as attached. I know the original comand looks better, but the Pioneer does everything you want and no need to buy updated maps from Mercedes. Just a note to say that the surround is yet to be fitted.
That looks as good as oem. I like it.
