jon rennison
- Jul 4, 2004
all right, I've got a 190e 1.8 auto that's leaking oil into the water cooling system, took head off as was sure was head gasket that had gone, it had but unfortunately this has caused corrosion to the block, worse pitting is about 0.25mm deap, cylinder head is pretty much spot on.
anyone got any ideas on what can be done to fix this problem? I'm thinking along lines of having to take block out and have it skimmed but how much can you have skimmed off as pistons seem to come right up to the top of the cylinders......
