amwebby
... was reported on a health check from my local MB dealer. Just tonight I noticed it making a noise on hard right lock. Does £225 all in sound good or bad for this (2000 W215) and how urgent is it?
If it passed the MOT then the wear hasn't reached a dangerous condition since badly worn track rod ends are an MOT failure item. The noise you are probably hearing is the power steering pump straining to move the steering linkage past full lock. It won't since its reached the "end stops" on the hub which prevent further movement. If you hear this you should back off the steering lock very slightly till the noise goes away. Its not good to take the steering to the limits like this since it puts a slight strain on the power steering pump and steering linkages. Ironically its often the reason why track rod ends get worn in the first place. As Olly says if its a track rod end RR it seems a bit expensive at £225.I'm guessing it's the latter, as the noise I hear is only on full lock. It passed and MOT at the same time as this health check but I have done over 3,000 miles since then as my wife is very ill in Addenbrookes, some 75 miles away.
