I have checked through the forum but I am not seeing the W638 vans.
Changed the Thermostat 3 weeks ago. Low temp forced me to change thermo. Cured that problem. Now, everythime the van engine gets to 80 -90 and of occassion 100. The van stops completely. Leave for 1.5 hours and sometimes restarts. If not wait till morning and all is fine. We did have a flash of EDC on the dash. But never returned. I dont have a MBSD. So cant check. Noone around within 200 miles has one. Changed fuel filter 1 week ago and no difference. Removed Feed pipe to the fuel filter, cranked engine over to check for fuel. Nothing. Tried sucking on fuel pipe to draw fuel, Nothing or just very very small amounts. Do I assume fuel pump is shafted HP or just the feed pump.???? or can it be at most the CPS which I am unable to find and images at not helping on duckduckgo. If you have possible answers could you help with images please. Its -10 where I am and the 2 hour trek home was not pleasant. Thank you.
