Hi, I have a really annoying problem that I just cant seem to find the solution too. I have a 2013 Diesel C220 with a 7G Tronic plus gearbox.
When the car gets to operating temperature, there is a jump in RPM before engaging in 4th gear. Sort of like a slipping manual gearbox. Once it is in 4th Gear the RPM's start slightly bouncing especially when going uphill or light on the throttle.
Also in first gear, the RPM's do drop before then quickly rising and going into second.
All other gears work perfectly fine. I have had the TCU scanned using STAR no faults showing. Also changed the gearbox oil and filter. Still no luck.
Note this is much worse when the car is warm, when it is cold it isn't very noticeable.
Please could anyone help before I end up changing the whole box/
