digre
- Jun 24, 2007
- Location
- Greenwich, Southeast London.
- W202 C200 Elegance, Silver
Hi all
I’m hoping one of you may be able to point me in the right direction with and engine problem I’m having.
I have a 1999 W202 Auto C200
If I floor the accelerator I can make the engine play up. It will start fine, run fine, but if I floor it, I can make it go crazy…the engine wont rev fully, and gets kind of stuck, as if it is running on only 3 cylinders. At idle it then jumps rather violently. If I then turn the engine off, remove the key then restart the problem goes away, until I floor it again.
On the motor way if I floor the gas pedal it doesn’t rev cleanly through the rev range. One moment it doesn’t have full power then it does, if anything more than normal, then it doesn’t
Any ideas…. It’s obviously electrical, but where???
Thanks in advance…….
