D
Deleted member 65149
Guest
I’m going to replace the existing standard radiator in our family bathroom with a wider and taller heated towel rail. The heating system is sealed and all the radiators are fed by 10mm Speedfit pipe coming out of the walls at central positions behind the radiators. I’m going to fit the towel rail with angled fittings to allow the pipe work to go straight into the stud partition wall (via a TRV and lock shield valve of course).
My question is, do I need to drain down the whole system as everywhere on t’Internet suggests? I’m guessing that all that advice is for good old-fashioned vented systems with header tanks and 15/22mm copper. Surely I can get away with completely shutting off all the rads at the same level and above the bathroom, then releasing the pressure on the system. In that way I’m hoping there’ll be very little water to drain off before taking off the bathroom rad and putting in a bit of new Speedfit. Does this sound ok? Also, since I’ll only be taking away a radiator full and a bit of water I’m guessing I won’t need to top up the inhibitor?
