PO546
Status
Not open for further replies.
Halldoc
Co Durham
C220 cdi blue efficiency
I have a w204 c220 cdi blue efficiency 2014 it has done only just under 60000 miles, I recently got fault code 2080 bank one sensor one so had this checked and changed the egt sensor with genuine mercedes part, now I have fault code p0546 the car is starting fine although the engine light is on, there is a hessitation intermittently at around 3200 rpm when accelerating hard, there also seems to be a slight reduction in power. The automatic gear change seems to be less smooth also. This happened after a long drive to North devon and back around 900 miles.
I have recently added forte regeneration fuild to a full tank of fuel to make sure the dpf is not clogged. Does anyone know why this fault would still be occuring or what could be causing this as I do not want to have to take this to mercedes and have my eye's removed.
Quote Reply
Report •••
Users who are viewing this thread​
Total: 1 (members: 1, guests: 0)
BoldItalicMore options…
Insert linkInsert imageMore options…
UndoMore options…
Preview
Font sizeText colorFont familyListAlignment
  • Align left
  • Align center
  • Align right
  • Justify text
Paragraph formatStrike-throughUnderlineInline spoilerInline code
SmiliesQuoteMediaInsert tableInsert horizontal lineSpoilerCode
RedoToggle BB codeRemove formattingDrafts
Write your reply...
Post reply
Attach files Insert quotes…
Similar threads​
[IMG alt="Marvellous"]https://forums.mbclub.co.uk/data/avatars/s/156/156807.jpg?1599472022[/IMG]
fault code P204F96 Gle coupe 2017 350d
Replies 0
Sep 7, 2020
C
W204 p2463 fault
Replies 0
Aug 17, 2020
[IMG alt="Jaykay0123"]https://forums.mbclub.co.uk/data/avatars/s/156/156584.jpg?1598471023[/IMG]
C250 w204 p0705 transmission range sensor circuit malfunction (prndl input) code lack of power
Replies 4
Aug 27, 2020
[IMG alt="Jaybridgette"]https://forums.mbclub.co.uk/data/avatars/s/156/156496.jpg?1598123776[/IMG]
Help 2004 Vito code
Replies 0
Aug 22, 2020
M
W204 C350 - ABS / ESP fault now !
Replies 10
Sep 17, 2020
Share
Forum software by XenForo® © 2010-2020 XenForo Ltd.
Why are you copying and pasting your existing thread? please stick to the original.
Status
