I have just tackled this today so took the opportunity to detail the work for others to refer to.
The job took no longer than 45 mins.
You will need a:
17mm Socket
10mm Socket
8mm Socket
Torx drive about 4mm (sorry I didn't look).
I have drawn up a diagram as well to refer to the belt travel. Its all on the PDF and is self explanatory.
You first need to remove the slam panel and then the radiator fan. Then the charge cooling hose to gain access to the belt.
Any questions, I am happy to answer.
https://www.dropbox.com/s/9edi1u7clhdciyl/Poly%20V%20Belt.pdf?dl=0
You will need a:
17mm Socket
10mm Socket
8mm Socket
