KLP 92
I've had a feeling that my MPG wasn't brilliant on my 320 CDI since i bought the car a few months back. I had a few things changed as the car was running badly when i purchased it:
MAS
EGR Valve
Air filter
Diesel filter
Diesel lines
2 injectors
Turbo + actuator
New exhasut, no cats (inc precat), full free flow system.
New hose from intercooler to EGR
My trip computer shows me 38mpg at a steady 80mph, not brilliant but not bad considering the size of the car. I didn't think anything of it until aka$h bought an identical car, same mileage and year build. His car shows 3 mpg more than mine does, both cars doing the came route following each other.
Well, its only 3 mpg, and at this point i should tell you that my car has been Brabus tuned
Now with the Brabus tuning box i shoudl be apparently getting better MPG cruising than stock, but not the case!!
I thought maybe my trip computer was inaccurate so before my trip to Gerrmany i filled the tank and drove a steady 80-85mph to Belgium, economical driving, no sudden bursts of acceleration and no traffic either. Stopped off in Brussels, trip computer stated 38.1mpg. Full tanked the car again and the MPG in reality was significantly worse, 30.2MPG!!
Now 30 MPG cruising at 80MPG is poor for a diesel, especsially when a V12 S Class gave 27.8mpg on the same run last year!! Now that figure is all motorway mileage so i would have expected at least 6-8mpg more, at the very least.
Well i filled the car up on both occasions i made sure the surface was flat to get an even level. I filled it up so i could see the diesel in the filler pipe.
My C270 CDI gave me 46mpg on the same run, i regularly do thhe europe trp so i kno what economy i should be getting.
Now bearing in mind the things i've changed already, what else could be causing me the poor MPG? I had 4 people ion the car, correct tyre pressures, AC off, feather touch acceleration......
Any help will be greatly appreciated or i may just have to buy a E220 CDI
MAS
EGR Valve
Air filter
Diesel filter
Diesel lines
2 injectors
Turbo + actuator
