television
Hardcore MB Enthusiast
He's got one good unit with a dodgy display and one bad unit with a good display.
No..??
On my quick read I thought the changing was to correct the error in the reading
No..??
That'd be the same as this 220 then.
http://cgi.ebay.co.uk/2000-MERCEDES...oryZ9855QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
All the CDi speedos go to 160mph.
Just makes me wonder because the difference in consumption is approximately 1.5 times as much which tallies with four or six fuel injectors.
I bought it from a breakers who said its from a e320 cdi, there's no part number on there! I'll find out on diagnostics when i code it.
But why would the 4 cyl cluster cause the real term mpg to be so poor?
A 4 cylinder rev counter would never work on a 5 or 6 it cant as it uses pulses from the CPS the more cylinders you have the more pulses to go with it. The IC could be changed over from the old one, this also applies to the injection and fule consumption rate
Not quite true for later model Mercedes I'm afraid, the cluster software contains the calculations for all variants, and is coded on the production line (or at the dealer in the case of a unit change) to the car variant to which it is to be fitted. This saves a lot of bother and expense having a different software and hardware for each model or sub-model.
Kind Regards
Matt
I suspect the variant coding is in the engine ECU then, and passed on to the transmission ECU. Someone with Star must be able to change it, as I remember Steve the independent mechanic in Maidstone telling me how confusingly complicated it is the number of things you have to code. With the Daimler development tool, you can code entire standard vehicle configurations in one go, or change individual components, like the axle ratio.
I wonder how much fuel you'll save dropping the revs at 80mph from 2500 to 2300?
I have a 200 mile trip in the morning so i'll be using my old cluster. I'll let you know how i get on and fingers crossed i continue with my 40mpg average from today!
Be interesting to hear how you get on. Fuel economy and low down grunt are the only things that would tempt me into a Cdi from an 300.
The 300 is a lot quieter and infinately more reliable.
Point accepted Matt and thank you, this means that the components are switchable either during manufacturing or on STAR
Would the info taken out be different and not contain the car model info, this would mean you still have to order new ones for the model that its needed for
You need to try OM651; It's quite nice![]()
Very true. I have the 250 engine in my W202 and i've spent less in maintenance on that in 4 years than in 6 months on the CDINothing ever goes wrong
(frantically touching wood)
I've driven the 300td back to back with the CDI. The TD is alot more laid back and relaxing to drive, the CDI is eager and alot more potent as well as more economical. The main reason i didn't go for one was i wanted a fully loaded one and facelifts were more readily available.
The TD can be sluggish in certian bands, nothing a rempa wouldn't fix! Finding a relatively rust free prefacelift is impossible as well!
My only regrets with the 300TD are that you do have to mine the performance to make it go as opposed to a quick stab of the accellerator, and it is too eager to change down a gear it could pull higher ratios no problem.
You are correct about the revs going above the torque band which is exaccerbated by the slow change down of the gearbox actually losing speed.
