Had a prob with my e class 300td traced to a vacume elbow cracked connected to the headlight adjusters i had no vacume hold , Simple check pull the vac pipe of the wastgate valve suck on it with your mouth and then cover with your tongue if your tongue is held to the end you have no vac loss , you may have to lengthen the pipe with another bit to reach , the elbow on mine was behind and below the ecu box , If you have no vac hold get someone else to then blow on the pipe and listen for the leak . simple and worked for me !
