Poor running with error codes - C55 AMG
LabourOLove
Manchester
W203 C55 AMG
Morning all,
My C55 is running poorly with erratic idle and sometimes cutting out completely whilst idling and/or with application of the throttle. Last week it went into limp mode and showed "ESP error - visit workshop". The ECU threw error codes P0102 "Mass or Volume Air Flow A Circuit Low" and P0221 "Throttle/Pedal Position Sensor/Switch B Circuit Range/Performance".
This issue has occurred previously. First time it happened I replaced the throttle pedal assembly with a used part, cleared the code and the problem seemed to go away. Second time, I replaced the MAF sensor, again with a used part from a breakers and the issue seemed to be cured for a couple of months. Now it has happened again and I'm at a loss. Could it be a problem with the throttle body?
Cheers
Ant
Used parts are of unknown provenance. It could be that either of the used parts you fitted is now itself unserviceable.
It put a genuine or Bosch MAF first with a pair of new air filters. Then re-set all the adaptions and throttle flap.
The used MAF I fitted is Bosch.
The car is in with Paul at MPH Prestige today. He mentioned straight off that it might just need the adaptions resetting. Should I be looking at a new MAF if the reset doesn't solve the issue?
Yes. They are almost a service item on 113's.
Morning all,
Cheers
Ant
As above fit a new Bosch maf.
I’ve fitted a new Bosch MAF and air filters. Is there a way of resetting the adaptations and throttle flap without STAR?
Nope. Some other diagnostic equipment maybe able to.
I bet it runs fine.
