grober
MB Master
I'm afraid I don't understand what you are saying? If the engine ECU is not connected then the engine won't run as it controls all the injectors? Are you sure you have removed the engine ECU?
I have the 94 car with the PMS, I am told that the PMS is no longer available, and if it is broken it cannot be repaired then the whole car is as good as scrap. I want to buy one as spare, or is there somebody who can repair it?That's OK now.
I have reconditioned the ecu.
Thanks.
I hope to make so many km
Thanks grober, I like your word “almost”They are effectively sealed units unlike the HFM boxes so repair is almost impossible.
[SOLVED] - W124 E200 with no ignition on cylinders 1 and 4
0185451132 is a much more common alternative part # that will work in your car. 0185454332 will also work but is just as hard to find as 4432.
They aren't coded, simple plug & play. They're on ebay all the time.
The PMS module was only fitted to some of the earlier W202 C class 4 Cylinder M111 models afaik--- there are very few of these cars still on the road meaning its probably not an economic proposition commercially speaking. The limited market being catered for by second hand parts.
Thanks grober! Have you tried making one?
