axelvic
Hi all!
I'm new to this forum, and this question may already have been answered elsewhere, I've not been able to find the answer though.
I've got an '01 E 320 CDI estate with an SRS-lamp that stays on. My local MB workshop read the codes and according to them it was the SRS module that was to blame.
I found a used module (with exactly the same part number) from Holland, replaced it and the light is still on. Now it flickers after the initial test phase though.
Naturally I thought it needed to be coded into the system, but my nearest MB workshop says I need a brand new module (£450) and them to replace the old one with it and code it (£300), which I obviously think is a bit expensive for such an old car.
I talked to another MB workshop a couple of hours drive away, and they said it might be possible to use the used one instead, they'd give it a go at least.
Does anyone know which is correct?
Thanks,
Axel,
Höganäs, Sweden
Thanks,
Axel,
Höganäs, Sweden
