Goldfish11
- Mar 22, 2004
- C220 CDI (09/11 - Facelift) & SLK200
Polish an E Class in 20 minutes, leaving no swirl and creating a near mirror finish. And using half the usual amount of polish or wax.
I did my car this weekend and my neighbours were queueing up to borrow the thing. We ended up doing the equivalent of 3 vehicles in 90 minutes. In minutes you achieve the same finish (or better) that hours of hand polishing would achieve. You can also get away with using less abrasive polishes to do the same job than if you were doing it by hand which is better for your paintwork.
As you can tell I am quite enthusiastic about this so thought it worth sharing my research.
I have put plenty of web links in so those who are interested can take a look without going through the pain I went through with the search engines.
My problem that drove me to this is changing from a silver to a nice Black Car. It looks great when it is clean but when dirty it looks horrid.
I also noticed when the sun shone on it that you could see lots of little fine scratches which are called swirl. These I think were caused by the MB (the previous owner) putting it through a car wash.
In the UK you can purchase a car polisher for anything between £10 and £45 these things you put a sheep skin bonnet on a then put some wax on this. They are low powered and can in some situations cause more damage due to their circular motion. They are like those kitchen gadgets that people buy use once and then never use again. They are OK at doing a basic application but will not solve any paint problems effectively.
The next step up is to go for an high speed circular motion polisher. These need to be used by professionals and can burn the paintwork or inflict serious swirl marks if operated by a the inexperienced.
A safe polisher needs to be “dual action” and or “random orbital motion”. These mimic the hand movement at about 4000 rpm. They cause no heat build up and are idiot proof, the only damage you can really do is by dropping the tool on the car. You can see these in action in the videos at the websites below.
Dual action / random orbital polishers use a foam sponge pad, different grades of foam can be used for different tasks. Mild cutting, polishing or applying a wax.
Through searching through the discussion forums on the net, for example, www.autopia.org , I have found two real options for the UK. Autopia is a US site for those who are car detailing geeks. (Detailing equals Valeting in the UK) So if you have any question about cleaning cars including what type of make-up brush to clean your dash with, this is one place to look.
Option 1 – Makita BO4060
http://www.makita.com/tools_Item_View.asp?id=218
This is a random orbital polisher/sander and can be purchased for about £230. The main benefit of this is it operates on 240volts, the down side is it seems less well tested by car enthusiasts. You will then need to purchase foam pads and these are about £14 each.
Option 2 – Porter Cable 7424 -
http://www.portercable.com/index.asp?e=547&p=2805
This dual action random orbital polisher seems to be the standard and is used extensively in the USA by many car enthusiasts. Lots of advice on its use is available, see for example, www.autopia.org
Meguiars the US car care manufacturers (who also supply all the Mercedes Benz Branded car care products, see leaflet ASM/586/0901) badge this machine. You can see one in action on a web video “Power Polishing Clinic”. There are also other videos about dealing with swirl and other car care issues.
http://www.extremecarcare.co.uk/meguiars.asp?cat=videos
or
http://www.meguiars.com/clinics/clinics_template.cfm
The only downside is it is not available in the UK, so you have to import one from the US. This however is not a problem between placing my order and receiving it from Autopia http://store.yahoo.com/cgi-bin/clink?autopia+MBWu4u+index.html+ it took just 3 working days!!
The second problem is it operates on 110 volts so you need to invest in a transformer or borrow one, this is not a bad thing with the English weather being as it is you reduce the chance of electrocuting yourself if it starts to rain.
The cost of getting set up with this system is:
Porter Cable 7424 plus hook and eye backing plate (needed so you can easily change pads) and 3 pads, one for polishing, one for finishing and one for more serious damage - $179 (see Autopia Kit link below)
(I also bought some additional pads because they only cost about £6 in the US compared with £14 in UK from Meguiars)
Postage was about $40
Total = £120 (at exchange rate of 1.85 dollars per £)
You may get stung for import duty but you may be lucky, this is about £25.
You then need to go to www.screwfix.com to get a 110volt set up. (Screwfix codes are in brackets)
You will need:
110volt plug (19947)
240volt to 110volt Transformer (16158)
110volt 14 meter extension lead (16691) (This is important as you should run the extension from the transformer not run a standard 240v extension to the transformer, I have been advised you may melt your 240v cable. So plug the transformer straight into the wall and then use 110v extension cables from this.)
Total Cost = £65
So the total Porter Cable set-up including pads is about £210.
When wiring the plug remember in the US : White is neutral, Black is live and Green is earth. See the following weblink for more details.
http://www.wordiq.com/definition/Power_plug
Now this may seem a lot of money but if you are investing in the £20 to 30K car this means you can really take care of it. I think I may charge a loan rate to the neighbours to recoup some of the costs!
Other useful web links:
http://mbclub.co.uk/forums/showthread.php?t=7294
http://autopia-carcare.com/inf-pc7424.html
Using a dual action Polisher. more tips
http://www.properautocare.com/witporcabpol.html
Discussion thread on UK users of Power Polishers
http://www.autopia.org/forums/showthread.php?s=&threadid=31867&highlight=makita
For foam pads in UK and an other discussion forum on paint care see:
www.meguiars.co.uk
Use of Porter Cable on German Paint finishes (German car manufacturers use a more flexible paint)
http://www.properautocare.com/aregepadi.html
It would be an honour if the moderators thought this worthy of going in the How to section?! :bannana: :bannana:
UPDATE: I have dropped a couple of before and after photos after using the polisher further down the tread (about position 18 on page 2). This is my wife's tropical green car which had not been polished for about 12 months. It is light coloured so it shows the potential benefit of using it on a silver car. (If you ignore the green!!)
UPDATE Goldfish11 - Winner Cleanest Car Competition MBClub UK Summer GTG. As the Certificate states "....has spent far too long washing, waxing and caressing their car, they need to get out a bit more!"
UPDATE To see how my obsession has developed see also http://mbclub.co.uk/forums/showthread.php?t=11481
A picture of the Porter Cable set up and result using Autoglym Super Resin.
