Power Down Comand
RussJ
Ferndown
Mercedes SL63 2013
I need to cut power to my Comand 4.7 in my SL63 231.
According to the fuse chart, #28 (20amp) supplies Comand.
I've pulled it but Comand still works!
Can't immediately see Comand mentioned elsewhere on the fuse chart so am a bit stuck.
Be grateful for any suggestions (other than disconnect the main battery which I'll keep as a last resort).
Russ
Sorry can't help regarding the fuses but am curious as to why you need to cut the power ?
Trying to resolve a mucked up SatNav update. Comand is in a loop asking for a DVD and one suggestion in Xentry is to cut power for 15mins.
I decided to just disconnect the main battery and needless to say it hasn't fixed the problem.
Back to the drawing board...
Hopefully the guys from Comand.co.uk will see this and offer a suggestion.
You almost certainly need Xentry or Vediamo, or to take the unit out and change hard-drive - depending on exactly what has happened during the map update - to fix this problem. Ive seen a unit stuck forever too - something got set in the flash-ram that couldn't be un-set (but that may have been a co-incidental failure)
Fuse is F26, 20Amp which is in front SAM fusebox. Not F28!
Richard
