ralf111
Hello,I have changed oil filter housing oring's because of quite big oil leak from one of them,unfortunately since that time engine not working properly,its hard to reach 3k revs also engine not start very well,i suppose that something was broken maybe cable or pressure hose from one of solenoid valves,but i cannot find visually anything at the moment,so i decided to take off again power steering pump and air condition compressor to get better view.
What i found that one of the fuses (15A) on the engine compartment has been blow of,i changed fuse and it's been blow off again,after that i found one of the cable was broken from oil pressure sensor,since i fixed that cable fuse is ok now,but the problem with engine working properly still persist.
I have some error codes which i think will suggest some electrical problem ?
Confirmed codes
P0245: Valve A electromagnetic turbocharger wastegate - Low input value
P0047: Electromagnetic circuit in the turbocharger / supercharging control system - Low input value
P2602: Cooling pump control circuit A - Low voltage circuit
P2006: Inlet manifold rotor control - blocked closed (bank 1)
P0688: ECM / PCM Power Relay Sense - Circuit / Open
P0685: Load relay in the ECM / PCM control circuit - Open circuit
B218E: Description not available
P2119: Throttle controller Checks throttle body range / performance
P1C49: Description not available
P0236: Turbo boost sensor A in the circuit - Range / Quality of the circuit
Not confirmed codes
Confirmed codes
Not confirmed codes
