power window problem
mrtidy
cheshire
E200 auto saloon
both the passenger and drivers side front power windows have stopped wprking for some reason,also the electric mirrors have stopped working too, this all stemmed from me trying to open the drivers power window the other dya wehn it wa frozen....doh..i,ve checked the fuses and they seem fine,could it be a realy?and if so where are they and how do i chech if they are ok and which is the one that may be knackered?any help would be appreciated...
Comfort relay?
Although i am unsure whether the mirrors also go through this...
the switches in your center console is one combined unit...4 windows - childlock - mirror adjustment and trunkrelease...the comands from this panel go through CANBUS to control units in the doors...might be something wrong with those in your car (although 2 at a time sounds like there is a different problem...).
Have the car connected to stardiagnose at MB to sort it out...either a CANBUS or control unit problem...
greetingz,
The exact same problem just happened to me today. Both front windows won't work, the same goes to the electric mirrors. The back windows work as normal though. Remote boot release works as normal. Have you solved your problem? Checked all the fuses (from engine compartment & boot) and they seem to be fine.
Oh, BTW, mine is C200 Sport/1998 S Reg.
