D
Deletedmember130310
Guest
Thought I'd take the car out this morning for a spin and quick check over before its MoT tomorrow as I only used it once in the last 6 moth (long, separate story)
All was good except the windscreen washer jets weren't working. Mmm - this will be an MoT fail tomorrow
Bottle full - check
Disconnect hoses - seem clear.
Blow air through nozzles - all good.
Check I can hear motor running when stalk pressed - mmm, no noise
Panic - this could be expensive
Check fuses etc - all ok
when in doubt, return to manual for any tips
Argh - I'd forgotten the stalk requires a double / deep press to activate the washers - the first stage merely activates the flick wipe...
All good
Panic over
Bottle full - check
All good
Panic over
