Blackestate
- May 4, 2012
- C240 sports estate
Hi All. I'm new to this forum. I have a 2000 C240 estate (W202) with 112k on the clock which has run perfectly since I bought it some 18 months ago. I'm a keen and competent DIY mechanic.
The car has began to fail to restart once warmed up and throws up an engine fault light. Opening the bonnet and thumping the fuse box seems to help. So far it has always restarted. If I could read the fault code it would be simple but there doesn't seem to be a reasonable priced reader on the market that works with this car. Is there any cheap device out there? or a workaround that allows access to the codes? Back in the 80s I used to work on american cars that had engine management and we could coerce them with a hair pin stuck in the right pins to flash their codes on the ign light. Does anyone know of a work around for the W202?
Thanks for reading this.
