AdamG
- Sep 16, 2006
- Location
- Bromley, Kent
- W210 E240 yr 2000 (stolen), W220 S320CDI (2003)
I want to change the oil in my s320cdi gearbox. I've heard you can get more oil out by spinning the engine with the start motor.
Last time I disconnected the crank shaft postion sensor but it was a right pain to get at and left a fault code that needed resetting.
What is the most convenient way to disable the engine from starting? Fuel pump relay?
Adam
Adam
