aka$h
Ive got a plate which is a letter 11 and three letters, I have had all of it spaced closer, and when I was pulled for speeding they didnt mention anything about it, only for MOT's i have to stick the normal plates over them.
Brian WH said:DO YOU REALLY WANT ALL THESE NUMBERS ON A WEB_SITE TO BE CLONED??????
Mr E said:Flip - would be very interested in seeing the regs in regard to treating the spacing of a "1" differently.....
Alfie said:Me too.
DITTRICH said:...I'm with Scott_uk on this one. Yes, plates can be cloned, but I'm not convinced it is very likely to happen. If someone points us towards some statistics to put the problem in perspective, then I might change my point of view on this, but until then, I'm not that fussed.
Les
Flip said:Yes, you're right. Your plate should be "T800 OST", but if it is just mis-spaced (but otherwise legiable) I figure they have better things to be doing.
K1NKY can be spaced with 13mm gaps between each character, K2 NKY has to have 13mm between all except the number and the group of characters (which needs to be 38mm).
These measurements are for the older style of charcters (which would have been current at time of issue).
With the current, narrow characters the distances are 11mm and 33mm respectively.
The fine for an illegiable plate? Depends on local policy. And whether the cop is a keen new recruit.
Could be as little as a warning, a £40 fixed penalty ticket (take it if offered!), £60 and 3 points or a summons to court (max fine £1000 I think). DVLA can (and will) withdraw plates.
:bannana:
Plodd said:You have lost me here. Why the difference in spacing for the K1 plate as opposed to the K2?????
Swiss Toni said:Section 13 (3) b & c refer to the space between the letter I or number 1 in a plate. (Page 10 of the document above).
Table B (3) & (4) show the distance can be the smaller 11mm (new style plate) / 13mm (old style plate) OR UPTO 33mm (new style) / 37mm (old style).
Allows K1NKY and K1 NKY to be legal, but K2NKY would have to be spaced K2 NKY in order to comply.
Swiss Toni said:http://www.dft.gov.uk/stellent/groups/dft_roads/documents/page/dft_roads_506805.pdf
I knew insomnia would come in useful eventually....
it's not even a legit ebay auction:neilrr said:Edit: Buried amongst all the bullsh*t he writes about this monstosity is a small but important fact - it's an insurance write off!
Paying through PAYPAL please add FOUR PERCENT to the final Total to cover PAYPAL charges otherwise item will not be sent out!
Morning Johnglojo said:So does that mean I could have :
N1EVE
Morning Shude
