Hi
I am having problems with my heater fan, also on a 2001 cdi.
The fan started to make a loud rumbling noise, then that stops and instead I get a high pitched noise. The noise has alternated over the day. I am only using the fan in short bursts due to misting, and to see if the noise has gone.
The loud rumbling sounds as though something is in the fan housing and flapping at high speed the noise is being accentuated in the ducting. When you turn off the fan as it slows it ticks as if something is hitting the fan blades as it slows.
The high pitched noise sounds as though the fan blades have come free from the motor shaft and so the motor is spinning far too fast.
The fan still appears to be blowing out air.
Question...
It appears from above that the fan is under the passenger dashboard.
Is the picture above, from Shude what I will see when I remove the cover in the passenger footwell, or is that picture taken from under the bonnet?
When those two tork screws (circled) are removed does the whole fan assembly come out allowing me access to the housing for the fan blades, so that I can clear any objects / check for damage?
Thanks for your help.
