Problem with window drop
Discussion in 'Parts, Maintenance & Servicing' started by 6cyl, May 17, 2018.
  1. 6cyl
    6cyl Hardcore MB Enthusiast
    306
    Aug 15, 2013
    London,UK.
    Car:
    CLS320 CDI
    I have a 2009 CLS. The driver's side windows started playing up last night.
    Open the door, window drops as normal. Close door, window doesn't go back up.
    Lock car, windows stays open about 10mm.
    • Door open sensor ?
    • Windows regulator ?
    • Expensive ?
    • Easy to diy ?
    Cheers
  2. hdhothar
    hdhothar New Member
    18
    Feb 21, 2011
    Kent
    Car:
    CLS 55 AMG
    Check the courtesy light switch. I had the same issue when I had the door card off and as the switch wasn't getting pressed, the window wouldn't go back up.
    6cyl likes this.
  3. OP
    OP
    6cyl
    306
    Aug 15, 2013
    London,UK.
    Car:
    CLS320 CDI
    Good call hdhothar. I'll check the light switch on the door.
  4. OP
    OP
    6cyl
    306
    Aug 15, 2013
    London,UK.
    Car:
    CLS320 CDI
    I've checked it, your were right, the light switch on the door is intermittent.
    I've pushed it in and out a few times which seems to have done the trick, doubt it'll last though.
    I presume the switch needs to be changed?
    I wonder what the construction is like, I may be able to get some switch cleaner on it.
    Thanks for your help hdhothar
  5. hdhothar
    hdhothar New Member
    18
    Feb 21, 2011
    Kent
    Car:
    CLS 55 AMG
    Looking at this one on ebay
    it should pop straight out. I think some wd40 might do the trick.
  6. wu56Shoozz
    wu56Shoozz Hardcore MB Enthusiast
    1,983
    Jun 17, 2016
    You'll need a passport to get over the Wall..
    Car:
    MB Vito 111CDi / W203 C Class Saloon 320CDi Avantgarde
    3in1 Oil or Silicone spray would be better..
Share This Page
