Baron_Samedi
If... I were to set about the brake pads on my W209, would I need to use STAR or similar to back off the ABS pump?
On VW's (pffft) like the Passat you should reset the ABS in VAG-COM before working.
I was wondering if MB have a similar requirement or whether you can jump straight in and lever (gently) back the brake pistons?
Oh and do you need a special tool to back off the rear brake pistons?
Ta
Ta
